Question USB 6009 DAQmx
Sorry for having created two topics.
But I'm in need of an orientation.
Could someone guide me, please
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Help-DAQmx-and-USB-6009/m-p/3088850
(3,808 Views)
It is bad form to post the same question to multiple forums.
You have already received two very helpful answers from crossrulz and Sam_Sharp.
(3,787 Views)
In his defence, I only saw the other thread because he posted this one. While I wouldn't encourage multiple posts and would always recommend that you post in the most appropriate board for your topic, I tend to only check the 'LabVIEW' board.
(blog)
(3,769 Views)
If you look at the time stamps on the two posts, you will see that he posted the same question on the LabVIEW board *after* you replied to his other post.
Apparently either your detailed answer wasn't satisfactory or he didn't understand your answer and thought that repeating the question yet again will yield a different outcome.
(3,763 Views)
Sam_Sharp
Thank you for your answer on my problem. I changed these points of the program.
thank you for help.
(3,752 Views)
