07-17-2014 03:31 AM
Hey guys,
Quick question about LF and CR. As you can see I am writing LF and CR into a text file and directly reading it back.
However, I am not getting the CR back when I read it. Why is this? Is this because Windows ignores the CR?
Solved! Go to Solution.
07-17-2014
04:27 AM
- last edited on
04-26-2026
03:02 PM
by
Content Cleaner
Hi dora,
read the help for the WriteText function.
There is an option for handling of CR/LF characters and it is explained mentioned in the "Advanced" section of the help article!
07-17-2014 08:19 AM
Yeah this is one of those rare cases where right clicking a primative gives you more options. From a interface prospective I like that this type of setting is quick to change and means less inputs to a subVI.
From a developer perspecive I feel like they are hiding features behind menus. Maybe if more functions supported right click options I would like it more, but as it is I think there are probably a dozen or so functions that do this. Array to Cluster, Format Into String, Scan From String, Read/Write Text File, VISA Write/Read, Compound Arithmatic, In Range and Coerce, and several XNodes have extra menus too. I probably missed some, but in the grand scheme of things where you have 100s of things on the palette, not many functions support this feature.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-20-2014 08:01 PM
Thanks guys,
I totally forgot about that some VIs had the right click options.
As hooovahh mentions, its a bit confusing that they would hide some aspects of certain VIs..
