Question about FTDI cables
so it is normal the fact that I see the signal changed?
"Word to the wise. Not only do RS232 level shifting devices (e.g. MAX232) level shift, but they also invert the signal."
this confuse me.
Message 11 of 17
(1,214 Views)
What version of FTDI are you using?
Fernando H. Solórzano
HW Automation Test Engineer
Message 12 of 17
(1,210 Views)
it is the TTL232RG-VREG3V3
Message 13 of 17
(1,208 Views)
Can you please try this setting on the visa and run your VI.
wVISA Configuration
What do you get out of it?
Message 14 of 17
(1,202 Views)
Hi ferchu. Always the same. One thing that is strange is that the FTDI that I'm using on the datasheet says 3V3 but when I measure it shows 5V.
Message 15 of 17
(1,187 Views)
Have you got a voltage regulator in place?
TTL-232RGVREG3V3-WE
USB to UART cable with +3.3V TTL
level UART signals. Maximum output
of 250mA on VCC
(see Note 2 and 5)
Wire Ended (no
connector)
6 core, UL2464 24 AWG,
diam=5mm
Note 2: Any regulator from 1.8V to 5V can be used. 1.8V and 3.3V versions are standard products.
Others values are customized at the factory.
Note 5: The VCC power output signal (RED wire) is 3.3V. The source of 3.3V is on board 3.3V regulator output, which
is switched onto the power output signal
Message 16 of 17
(1,180 Views)
the cable is connected to the pc-usb. the measurement has been done with a professional tester.
Message 17 of 17
(1,174 Views)
