Question about array of cluster
Hello everyone,
Now I have an array of cluster. The cluster is made of two elements (x,y). Now I want to find the minimal value of y, and its corresponding x. So how should I do this?
Thank you.
(3,289 Views)
Accepted by topic author zyb1003
I would use a For Loop to unbundle just the Y elements into their own array, then use the Array Max & Min function to find the index of that Min Y value of that new array. Once you've got that, then use that index on the cluster array and unbundle just the X value.
-Preston
(3,282 Views)
