Question about assign 1d clusters of array with 8 elements to 8 double [64-bit real(~15digit precision)]
I have no idea that how to assign 1d clusters of array with 8 elements to 8 single numeric constants.
Could you give me some suggestions on the methods and what widgets should I use in block diagram to do this.
Any help will be appreciated and thanks in advance.
(2,959 Views)
It's hard to say without seeing specifically how you data is set up.
Attach a VI that contains the data you have, and an indicator that is setup to what you want.  (8 double, is that 8 scalars?  an 8 element array?)
(2,943 Views)
I have attatched two files in the attatchment. One is test.vi(the block diagram), another is VI that contains the data (niScope Multi Fetch Array Measurement Cluster.vi)
I want 8 double scalars from 1d clusters of array with 8 elements in wfm info contained the data in NI scope multi fetch array measurement cluster.vi.
Thanks.
(2,935 Views)
Use Index Array to get the 1st cluster element out of the array.  (What do you want to do with all the other elements in that array?)
Unbundle by Name to get each element of that cluster.
(2,925 Views)
Now it works, I am new learner in labview and just as practice purposes.
Thank you very much.
(2,907 Views)
