Question about making printible reports by reading data from database
We have a pressure test system which we want analyze and plot the instant pressure values in a pre-defined time interval. After each test we want the record the test results along with the other information(date, time, operator name, test no, product type, product number, etc.) added by the system operator. The data will be recorded to an access data base. Doing that, we want to make test results archive which we can make search within, to list the past test results, searching by date, seraching by product number, or searching by any other information in the database. Plus, in the future, we want to be able to take reports of these past test results, including the pressure/time graph and other information added by the system operator. Also we want to set the report format.
My question is, is it possible to do this with LABVIEW 8.2? Do we need any toolkits or add-ons?
Regards
(2,432 Views)
Hi, Hasan.
That would be an excellent use of LabVIEW. At the very least, you'll probably want to get the Database Connectivity Toolkit, and depending on your needs you may also want the Report Generation Toolkit. There are a lot of tools in the LabVIEW Development Environment for generating reports dynamically, but the Report Generation Toolkit includes a lot of advanced functionality not included in regular LabVIEW installations.
That said, however, I really recommend you speak with one of our sales representatives to make sure you have everything you need. Since I know so little about how you'd be implementing each step of that process, I'm reluctant to guarantee it, and one of our representatives can tell you with much more certainty. You can get in touch with one from ni.com/contact.
Good luck! Have a nice evening.
Sarah K.
Search PME
(2,418 Views)
