Question about online exams
I'm signed up to take the CLA online, and this will be my first online exam with NI.
Someone made a comment I didn't quite understand on an old forum post about needing a separate webcam so you can close your laptop. Can anyone speak to this? Will I be able to use my laptop webcam while using a separate larger monitor for the exam or will I have to have my laptop closed?
(855 Views)
It's been quite a long time since I've taken an online test, but I think you can only have one active monitor.  If that is true, then that person is correct.  One piece of advice.  Make sure the room your are using is clean!  They will ask you to point around the room, and even under your desk, to make sure you don't have any "cheat sheets" sitting around.
Bill
CLD
(Mid-Level minion.)
(850 Views)
