Question about running the daqmx example
I'm trying to run DAQMX examples I found on find examples (Digital output on DAQMX section)  ( on labview help) on my NI9485. But when I run the Vis ..nothing happens. But when I test my modulator with Daq Assistant it works. What am I doing wrong?
Message 1 of 8
(4,235 Views)
Please show us what you are doing
Message 2 of 8
(4,219 Views)
I'll post once I'm on my laptop . I just ran the vi on finding example . Vi is called digital output
Message 3 of 8
(4,199 Views)
This one.
Message 4 of 8
(4,197 Views)
Nothing happens?
One thing happens.  You write a True value to the channel which sends it high.  Then it keeps doing that same thing over and over and over, which isn't going to look like anything because you aren't changing the value.
What do you expect the VI to do?
Message 5 of 8
(4,184 Views)
When I send true or false with daq assistant,  the resistance on  my device that is attached to my daq goes up and down . This time it didn't
Message 6 of 8
(4,161 Views)
But you are never sending a false in your code.  You are only sending a true.
Message 7 of 8
(4,152 Views)
As mentioned by RavensFan, the code snippet you included is only sending a true value.
Are you seeing the same resistance at your device as when you use DAQ assistant to send true? Are you able to probe the output line to ensure it goes high?
Alex
Hardware Engineer
Message 8 of 8
(4,111 Views)
