Question about sessions in LabView????
Hallo
I need to know how work sessions in LabView
I have a computer and some external devices as power meter, wafer
prober and etc.
What should I do if I want to initialize these devices in one system.
How can I receive session numbers for my devices?
I can "speak" to each of device abd they understand me and make my
commands correctly.
But I dont have any idea how to connect everything together (GPIB of
course) and how to have good session numbers.
Could anybody help me and explain that?
JOHN
(2,953 Views)
Hi John,
find attached a jpeg - picture from an init-sub.vi. There you can see, that this initialization phase consists of some sub.vi's who are in charge to init different equipment. The main thing is: an error-line is used to make sure the order of execution. You should do this in a similar way. Some init vi's are inside case-structures; these instruments are not in use for all of the measurements.
Hope this gives you an idea, how your problem might be solved.
regards
wha
(2,953 Views)
