Question about slow rs232 equipment
I tried the examples for rs232 communication, it works fine.
but my equipment is slow and needs delay between each character.
i didnt find any input to Visa write or other control which enables me
to do this.
can someone tell me how to do this?
again: to make a delay (inter digit pause) between each character send.
thanks in advance
Message 1 of 8
(3,112 Views)
It's quite easy. You split the string you want to send into an array of characters, and then using a for-loop write each character one at a time, followed by a small wait (whatever your instrument requires).
Regards
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 2 of 8
(3,112 Views)
Normally there should not be the need to have a delay between the characters. Are you sure you configured your baudrate correct?
Message 3 of 8
(3,112 Views)
I've come across equipment where a certain command needed delays between characters in order to be recognised, because its microcontroller was too busy doing something else... Admittedly this was a product of the company I worked for at the time and was somewhat funky, but many commercial instruments have been known to show funky behaviour!
Message 4 of 8
(3,112 Views)
If there is no receive buffer for the Serial controller, i might happen. But I thought there is a recieve buffer for every Rs232 controller , but who knows.....
Message 5 of 8
(3,112 Views)
If the microcontroller doesn't have a stand-alone async serial port, it's necessary to bit-bang data in and out. When doing that there's no inherent buffering - the microcontroller has to be programmed to sample (and usually oversample) the incoming data stream to reconstruct the bits into a byte, which can then be stored. If the microcontroller has to accomplish other tasks too, and it doesn't have enough horsepower, or the programmer wasn't skilled at making it perform multiple tasks, characters can be lost. Most current microcontrollers make this so much easier!
Bob
Message 6 of 8
(3,112 Views)
A PIC for instance does not have a FIFO for its standard serial port module. You get a byte in a register and if you are not fast enough before the next byte is ready things might go wrong. Of course writing the PIC formware in such a way that it can always deal with the maximum input rate (for instance 9600 baud => ~1ms per byte) is the real art here.
Also you can consider handshaking too, although the PIC module does not have this automatically.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 7 of 8
(3,112 Views)
I have had the same problem. Here's the VI I use to add a delay between characters.
Message 8 of 8
(3,112 Views)
