Question about strip charts
My question is quite simple:
I have a sequence, with let say 2 frames, in each one of them, there is a loop in which data flows.  I have created a strip chart which plot the data from the first loop.
What I want:
I would like to keep the same chart so that when the loop in 1 is over, it starts plotting the data from the second loop.
Thank you,
Noel
and in similarly, I would like to know how to use one numeric input and use it in 2 different loops without having to make the wire go all around the VI.
Message Edited by Akatsuki on 11-28-2005 05:35 PM
(2,768 Views)
Hi Akatsuki,
For your strip chart query, I think you are looking for something in the vi attached.
 Similiarly for updating a numeric indicator from two loops, use either propery node of that indicator(just like property node used for chart), or use a local or global variables.
Each of these have their pros and cons , so read about them and then decide on which to use.
regards
Dev
(2,747 Views)
Sorry,
herez the VI 😉
(2,745 Views)
