Question on pulse generator
I have (2) NI 9401 and cDAQ-9172.  I try to setup the NI 9401 to output a single pulse with pulse width of 20ms.  When triggering, NI 9401 would output a square wave ON for 20ms "solid", then turn the square wave OFF after that.
I would like to do this repeatedly every 20ms, 50ms, up to 1s in a loop.  I want to be able to set the loop repeat time and the pulse width of the signal.
I am wondering if there is a sample program I can follow.  I would appreciate very much if you could help me with a sample program that I could use for this experiment.
Thank you very much
-Khoa
(3,396 Views)
Hi Khoa,
Thanks for the posts, but this seems to be duplicate!
Please only post once - I will look into this post and answer it on the other.
Kind Regards,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,374 Views)
