Question on remote instrument communication
HI All,
I have a keysight instrument connected to a remote PC through USB (but it gets an IP address -- may be virtual network IP). From my local PC, i am trying to communicate with this instrument.
NIMAX can see the instrument under "Remote systems --> IP address of remote PC --> Devices --> VISA TCP/IP resource" and can communicate through "VISA Test Panel".
However, If i try to communicate to the same instrument using Labview (LV2020, Windows 11 64 bit), it is throwing me a resource not found error.
Thank you in advance for your suggestions/help.
(597 Views)
So your pc is connected to a remote pc, the remote pc is connected to a keysight instruments on USB.
Does NI MAx works when you send "*IDN?\n" over TCP/IP ?
What do you have running on both Remote and local ?
Please share your code for LV 2020.
(547 Views)
Hi LVNinja,
Thanks for responding.
Yes
Yes, as shown in Figure.
If you are asking about OS, they both are Windows 11 64 bit. On my PC, LV2020 and on remote PC i enabled the NI VISA server, thats how i was able to communicate through NIMax through "VISA:\\" address.
Code is exactly a "VISA open" subvi where i am getting an error. I did not add any more subvi's yet. As shown in picture, in the first subvi itself i am getting an error.
(538 Views)
