Question(s) about the Active Cell:Position property node for a table control
   What determines the Active Cell Position property node for a table control? I have this in my code and I am displaying its value to a front panel indicator. The value displayed is always set to 0,0. The help for the property node say that it is "read -only" so what sets the value of Active Cell Position  for a Table Control?
Kaspar
(3,659 Views)
Accepted by topic author Kaspar
You set the active cell with a property node.  Once you select an active cell, you can do specific things to that cell and that cell alone, things like set the background color.
(3,637 Views)
  Thansk for getting back to me. I initially assumed that the value of the "Active Cell Position" would change based upon the table cell that I clicked on, The "EditPos" property Node does that. I just have to remember to programtically (or manually) set the value of the Active cell position before I change the characteristics of the selected cell.
Kaspar
(3,613 Views)
