Question with array manipulation-PLEASE HELP
Hello:
I have a question about array manipulation, I have a 1-D array of clusters of 4 elements.  I am trying to take two clusters at a time from that array and build a 2-D array.  This is probably trivial, but I am going nuts trying to get it to work.  Any help would be appreciated.
JC
(3,322 Views)
I'm not 100% sure what your asking for, but if you want to convert a 1D array to a 2D array (of the same type) then you can use the reshape array function.
(3,314 Views)
I have labview 7.1 only, cant open newer version.  But that reshape array function looks good, by wiring arraysize/2 to the second dimention input of reshape array makes it dynamic, think it should do the trick.  Learned something new today, I was going to do this with a nested for loops, but this is obviously superior, thanks again.
(3,304 Views)
