Questions about Imaq Vision Builder
Recently I have acquired the new version of Imaq Vision Builder (version
6.0).
I have tried all the functionalities and demo programs, but I have several
doubts:
- The option from the menu "File->Browse Images ..." don't look to work very
well.
- Several options, as "Image->Line Profile" can't to be inserted into the
script.
- Sometimes it is not possible to set the parameters, for example with
"Image->Image Mask" Function. You can only see the coordinates or sizes
after you apply the function.
Miguel.
(2,672 Views)
Hi Miguel,
- "Browe Images" simply puts Vision Builder back into Browser mode. If you have multiple images opened, and you hit File->Browse Images, you will see all your images in the image broswer.
- The first 4 functions under the Image selection are designed to work as tools to analyze an image. They don't alter the image so it's not inserted into the script after execution.
I will document the feedback you have provided.
Thanks!
Ken Sun
Applications Engineering
(2,672 Views)
