Questions about waveform integration
Good morning gents, I am new to Labview and I would ask you something about integrated waveforms.
I have a waveform signal and I have tried to integrate it in different ways (see pictures attached).
The results plotted on the graphs seems fine and right (I think integrated waveform 1 is the correct one), but I cannot understand well why in the other graphs the time scale on the x axis varies and why also the amplitude on the y axis is different in the integrated waveform 3.
I think that the problem regards the dt of the signal.
I want also ask which are the differences between the integral blocks I used.
Finally I would like to ask some suggestions on how to correct the visible "offset error" on the integrated signals and how to implement this offset error correction.
(4,199 Views)
We cannot run or debug images. (Especially if there are express VIs, a lot is hidden from view).
Please attach your VI instead. Make sure it contains some typical default data for the signal array. Thanks.
(SIDE NOTE: to get an element of an array, "index array" is the right tool. Doing an "array to cluster ...unbundle" dance is not the right way...)
(4,186 Views)
Thank you for your suggestion.
Here I attach my VI, it is basic and simple.
I cannot attach the data  I work with because the .pnrf is not accepted as a format I can send here.
But the signal that comes out from from the read data channel is an array of waveforms and every signal contains a current waveform and a voltage waveform.
(4,158 Views)
But .zip files are an accepted format!  So just zip up your file and attach it.
(4,124 Views)
ZIP FILE: I cannot attach the data I work with,but I attach a test .pnrf file with two sinusoidal signals.
You can import on labview via hbmpnrf plug in.
(4,105 Views)
The time scale issue to due to the fact that your last 2 graphs have nothing to give them a time reference.  Use Build Waveform to just change the Y portion of your waveform to use the new integration array.
The amplitude of the third waveform is different because you did not supply a dt.  Integration involves a multiplication of dt.
Here is a much cleaned up version of your code that should fix what you are having issues with.
(4,102 Views)
No need to attach the data. Simply run the VI until it displays typical data. Now right-click the terminal of the "Original waveform" graph, followed by "create constant". Now delete the upstream code, the constant has a copy of the data. Save the VI under a new name (it will be a little larger on disk) and attach it here. (Please also give it a reasonable and unique name to prevent confusion. My downloads folder already has several "Try.vi", so the browser will rename yours to e.g. Try(3).vi when I try to download, potentially making me to open the wrong code by accident. A better filename might be WaveformIntegrationTest.vi, for example)
(4,082 Views)
