Questions: calling vi dynamically using vi server
I have a few questions on the following vi.
1. Is there a better way to determine at run time whether a vi is part of a build or not?
2. Is there a better way to pass values to a dynamically called vi.  Or better yet, a better way to call a vi dynamically?
3.  When I run the code as pictured above in a build the vi doesn't actually open. It opens fine when it's not a build.  However, when I call the vi dynamically, and enable the vi in the bottom right, 2 windows will pop up, the dynamic one and the other one.  Any clues as to what is happening here?
Message Edited by elset191 on 04-15-2009 03:59 PM
Tim Elsey
Certified LabVIEW Architect
(4,415 Views)
Accepted by topic author elset191
Did you make sure your disabled VI is listed as VI to be included in the build specification?  If you didn't, when the VI is build into an .exe, the disable diagram block and the VI within it are probably being stripped from the .exe
(4,405 Views)
That solved number 3.
Are there any suggestions to clean up #1 or #2?
Tim Elsey
(4,397 Views)
for #2.....
Use global variables to pass data dynamically .......
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(4,371 Views)
Anil Reddy wrote:
for #2.....
Rather than a global variable (shiver) I would use a queue to pass the parameters. A seperate queue for each created clone lets me interact with the deisred instance. Sans queues you would have to work out a handshaking mechanism to ensure the right values got sent to the right instance.
Short of that just using a single control that is a cluster with all of those values would let me do it with a single invoke node.
If all of those values are static, your way be OK except... the For Loop
Use a shift register for the error cluster so you do not loose errors reporting.
Ben
(4,354 Views)
