Questions on synchronization between analog input and output
Another "gotcha" that you should watch to avoid is the sample rate is not always what we specify. DAQmx will find a rate as close to the desired as it can support. The output of the Timing DAQmx function will return the actual sample rate.
Ben
Message 11 of 11
(1,006 Views)
