Queue between acquisition and processing loop
Hi guys,
I would like to acquire and process data in parallel. I have bought a queue between the two loops. The problem is that the program is really instable. Sometimes it looks working and some time you see the processing loop doesn't have any iteration. Could you please help me to understand where is the problem? I have bought a simplefied .vi to better focus the problem.
Thank you in advance, this probably simple problem is making me crazy.
Message 1 of 9
(2,758 Views)
Your simplified example runs fine here.  Well, mostly fine.  Loop termination isn't handled well, but that wasn't the issue you were asking about.   I see the processing loop iterate just fine whenever the GUI boolean is True, and pause when it's False as it gets stuck waiting at the Dequeue with a (default) infinite timeout.
Can you explain your question more completely?  Exactly what problem(s) do you have with this example code?
-Kevin P
Message 2 of 9
(2,747 Views)
You are not stopping your consumer loop properly. Since you have no timeout on the Dequeue, the consumer loop will wait forever. Even though you hit the stop button and terminated the producer loop, your consumer loop is still waiting on the queue and therefor does not stop. For any producer/consumer framework I prefer to use a message oriented approach for the data. Rather than passed the raw data, I would use a cluster with a message ID and data (a variant). This way you can send a Stop message to the consumer which will allow it to dequeue the data and stop. this makes it easier to expand your functionality if needed. The there way to ensure that the loop will exit is to destroy the queue immediately when exiting your producer loop. However, then you will need to use a case structure in your consumer to catch the error when the queue gets destroyed. Again, this will allow your consumer loop to exit.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 9
(2,745 Views)
You definitely should be using some type of message to tell the consumer loop to stop instead of relying on a local variable.  In this situation, I have used an empty array as a sentinel to tell the consumer to stop.  The consumer should then destroy the queue.
For a more robust setup here, you might want to look into using Channel Wires.  The Channel Wires have the added benefit of being able to insert a "final value" (or something similar) flag, a much better way to tell the loop to stop.
Message 4 of 9
(2,731 Views)
Remove the local variable and connect the error wire instead. Move the destroy queue to after the top loop.
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 9
(2,725 Views)
Hi Kevin,
thank you for your reply.
The problem is that sometimes it doesn't work. I think it is caused by the fact that the stop does not work properly and when the .vi is relaunched the program sometimes fails to build a queue.
I've tried to build the stop according to the example but it doesn't work. Can you help me to understand why?
Thank you in advance.
P.s. attached the screenshot of the example from Labview.
Message 6 of 9
(2,720 Views)
I have the opinion that this is a HORRIBLE idea.  If you destroy the queue while there are more samples in the queue, then you lost all of that data that still has to be processed.  As previously stated, we need to send a flag of some sort telling the consumer that it has processed the last data point.
Message 7 of 9
(2,703 Views)
And here's the Producer-Consumer Design using the Stream Channel Wire.  Note there's not even a place for an Error Wire in this design!  The top (Producer) loop has a "Save" button which is wired to the "Element Valid?" input of the Stream Writer, so no Case Statement is needed to turn on and off the flow of data.  Similarly, the Stop button that ends the Producer Loop is also wired to the "Last Element?" input of the Stream Writer to tell the Consumer when the Producer has finished.
I have placed the Producer Loop below the Consumer Loop, and have "snaked" the Channel so that it comes into the Consumer Loop from the left.  Note that you could also place them side-by-side, with a very short Channel going out from the Producer and in to the Consumer.  Note that the Case Statement removed from the Producer has appeared in the Consumer -- if "Element Valid?" is false, it is not added to the Output Array.  Furthermore, the "Last Element?" output is used to stop the Consumer Loop.  Finally, the Stream is created by the Stream Reader, and is released when Last Element? is asserted.
Bob Schor
Message 8 of 9
(2,702 Views)
Thank you all for your help.
Many interessting solutions.
I've chosen the solution of "crossrulz", (genial trick) and I found interessting the solution of the main stream.
Thanks anyway to everyone for your time and your promptness.
Un saluto,
crash
Message 9 of 9
(2,687 Views)
