Quick question GPIB error report vi
where is this vi located in labVIEW v6.1?
i tried searching for it in the functions pallette but couldnt find it,
thanks in advance,
Staunton
(3,606 Views)
I don't recall this VI. Is it used by some driver or did you use it in some old version of LabVIEW?
(3,606 Views)
Yes it was used in an old driver by a former colleage of mine, which i have to modify, i can copy and paste this from his VI but was just wondering if it was still available, the VI itself is shaped like a speech bubble in the block diagram, and it does show up in the context help dialog box, which is why i thought it should be still around somewhere, but it seems like its not.
thanks for your response,
Staunton
(3,606 Views)
The VI could have been modified from simple or general error handler by whoever wrote the driver. Also, any VI with a entry in the VI Description of VI Properties will the text displayed in the context window, not just VI's from NI.
(3,606 Views)
i found this subVI also in an example VI shipped with V6.1, find examples>hardware input and output>GPIB>LabVIEW<->gpib.vi
(3,606 Views)
staunton wrote in news:506500000005000000F5110100-
1042324653000@exchange.ni.com:
Yup, I see it, and here's the revision history:
-rev. 1 28 Jun 1994 00:57:15 Apostolos K
-SubVIs of this VI were modified.
-VI was converted from LabVIEW version 3.0.1 to LabVIEW version 3.1a16.
1994!!!
If you need it, just copy it from its current location to somewhere in your
VI folder:
LabVIEW 6.1\examples\instr\smplgpib.llb\GPIB Error Report.vi
Andrew
(3,606 Views)
