QuickDrop - Add object in LV 2016
In LV2015 and before, I could add my own front panel object by saving a copy of it in the  <LabVIEW>/resource/dialog/QuickDrop folder and adding a shortcut with the file name in the Labview.ini file.
It does not work with LabVIEW 2016 anymore. Anyone can tell me how I can use Quickdrop to insert my own front panel objects with LabVIEW 2016?
Marc Dubois
(3,664 Views)
Accepted by topic author MarcDub
MarcDub wrote:  Anyone can tell me how I can use Quickdrop to insert my own front panel objects with LabVIEW 2016
Objects should be in your user.lib folder as *.ctl or *.vi and added to your palette.  Only shortcut plugins should be in the QuickDrop folder.
(3,652 Views)
Thanks crossrulz,
That's the "adding to palette" that I forgot. Crazy what a year can do to your brain.
Marc Dubois
(3,622 Views)
