Quickly run a exe
Hi all,
I made a simple exe which is called in a special program (no C, no Labview...).
The exe is a single vi which the exe arguments, write data on C:\, and close.
The problem is that launching the executable take "a lot" (several seconds) of time, and if my program call the exe 2 times in a few moment, the second isn't recorded...
Is there a way not to open the front panel of the main vi ?
Any other idea ?
Best Regards,
V-F
Message 1 of 14
(4,578 Views)
There are several ways to not open the front panel. One method is shown in this link https://decibel.ni.com/content/docs/DOC-14607. Not showing the front panel might not fix your problem though. The delay you are experiencing may be part of the time launching the run-time engine.
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
Message 2 of 14
(4,566 Views)
the link you provided doesn't work...
My exe seems to be quick to launch, but slow to close, is it true ?
Best Regards,
V-F
Message 3 of 14
(4,535 Views)
hi tr.....!!
since i am using 7.1 version m nt able to find a fnt called "check if file or folder exits " in the selected path ,so cud anyone plezz help me in this regard ,humble request,plezzzzzzzzz!!:mansad:Smiley Indifferent,
i hav also attached my code ,since m a begginer in lab view i wud always welcome ur feedbacks .........
 thanking u.......
thanking you
LAKSHMAN C G
Message 4 of 14
(4,529 Views)
Hi setty,
Why do you post in this thread ???
Get out !!!!!
V-F
Message 5 of 14
(4,527 Views)
hey m sorry, cud u plez let me know how to add a question in the NI forum ,since m very new to lab view cud u plez let me know regarding this.....!!
thanking you
LAKSHMAN C G
Message 6 of 14
(4,524 Views)
type a question on research field, and a "post" this question appears...
Best Regards,
V-F
Message 7 of 14
(4,518 Views)
thank u soo much lol!!
with regards
LAKSHMAN C G
thanking you
LAKSHMAN C G
Message 8 of 14
(4,511 Views)
Hi Ramses,
Type into the Search field "DOC-14607" and you will find the document.
If the Exe closes slow, the question is, how do you terminate your program?
Greets, Dave
Message 9 of 14
(4,496 Views)
HI,
this doesn't run the exe in "silent" mode : there is the application icon in task bar...
Best Regards,
V-F
Message 10 of 14
(4,490 Views)
