Quintic spline filter
Does anybody know if LabVIEW provides Quintic spline filter (or 5th order spline)?
Thanks!
(3,014 Views)
Hi Back10,
Please take a look at the B-Spline Fit.vi. This VI allows you to do higher order spline fitting. The example that uses this VI function is "B Spline Fitting Demo.vi" which you can locate at Help>>Example Finder then browse to Analyzing and Processing Signals >> Curve Fitting and Interpolation >> B Spline Fitting Demo.vi. I beleive this will help you accomplish what you need. Good luck.
(2,989 Views)
Thank you very much for replying! It appears that B-spline fit is the solution!
(2,978 Views)
