Quit Method and SaveChanges
Dear All,
How can i configure the ActiveX Quit Method to allow Save a Word Document without popup (asking if i want to Save the changes). In the Quit Method, there is a SaveChanges parameter, but i don't know how can i configure it to avoid the popup. The goal is to overwrite the document without asking anything. I've tried to create a constant, control, lots of things to configure the SaveChanges parameter, but fail.
Could you help me..
Thanks in advance,
Hugo Neto
(2,920 Views)
You should be able to wire a constant TRUE into the SaveChanges parameter.
Your preferred solution is to save the document before quitting. This requires a reference to the open Workbook. Use the method Workbook.Save. This will overwrite the the original document which was opened and modified.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(2,912 Views)
Hi Michael,
Fantastic... So easy!
Done...
Thank's a lot
Best Regards,
Hugo Neto
(2,904 Views)
