Récupération d'event lors du lancement d'un exe développer en C sous LabView
Je lance un exe par la fonction Systen exe.vi, celui ci génére un event que je souhaite récupérer sous LabView 8.2.
Est ce possible et si oui comment faire pour se synchroniser sur cet event.
La fonction que j'utilise en C est "hEvent = OpenEvent(SYNCHRONIZE,TRUE,"event1");
Par avance merci pour votre aide
Message 1 of 11
(3,592 Views)
Translation
I launch an exe Systen exe.vi function, that it generates an event that I want to recover under LabView 8.2.
Is this possible and if so how to sync this event.
The function I use in C is "hEvent OpenEvent = (SYNCHRONIZE, TRUE," event1 ");
Message 2 of 11
(3,581 Views)
To use the OpenEvent function, you have to call the Win32 API in LabVIEW as it is a Windows Event. In order to do that, you have to use the Call Library Function Node in LabVIEW.
Here is a link to the LabVIEW 8.2 Help of this function. This link might also be useful to help you understand how call to a Win32 API can be done : Example 3: Call the Win32 API. Here is a link for the OpenEvent function details in the MSDN Library. And finally this is a forum post from a user who is using the Call Library Function Node to call CreateEvent which will give you a good example on how to use it.
I hope this will help you,
Message 3 of 11
(3,535 Views)
  HI,
  Thanks for the answer but I can't do it. I have always an LabView error
  Follow my vi try
Message 4 of 11
(3,501 Views)
what is the error that you are getting?
Message 5 of 11
(3,485 Views)
See the screen copy of the error.
Message 6 of 11
(3,482 Views)
Message 7 of 11
(3,480 Views)
  I assume it's a call problem but I can't determine what is the cause  of the crash.
  If somebody can help me to found the reason of it.
Message 8 of 11
(3,476 Views)
Utilisant de le "stdcall (WINAPI)" a resolu ce probleme pour moi dans le passe.
- tbob
Inventor of the WORM Global
Message 9 of 11
(3,452 Views)
    It doesn't work by changing the Calling convention but what Labview version do you use.
    We can see the Function prototype it isn't the same.
      hEvent is declare as non signed integer 32 bits
      dwDesiredAccess is declare as non signed integer 64 bit    value
      bInheritHandle is declare as signed integer 8 bit   value
      lpName is declare as signed integer 8 bit    pointer
    See screen copy file
Message 10 of 11
(3,437 Views)
