R&S NRP-Z81
I have a R&S NRP-Z81, and i am trying to read the data using labVIEw. So far I am able to control the frequency and read the average power. Buti also want to measure the RMS and peak.
There is an Vi in labVIEW for it called: "RSNRPZ Get Scope Measurements Pulse Power", However I am not able to use , it. Is there any expert that can help me, See encirccled the problem vi
(3,917 Views)
Your png is not in the least bit helpful.
(3,906 Views)
What do you mean by "not able to use". From the picture we can only tell you that there are no indicators wired to the outputs of the encircled vi.
Ben64
(3,891 Views)
I have the following labVIEW program. This program must read the power from an R&S NRP-Z81 power sensor and display the data. This program has an issue in viewing the maximum power. I don't how where I made the mistake or did something wrong in the coupling can someone help me. I have included all the files
(3,868 Views)
(3,868 Views)
