R&S HMO1002 ROHDE & SCHWARZ, Oscilloscope Help needed quickly
I'm using a R&S HMO1002 ROHDE & SCHWARZ, Oscilloscope.
I try to read the phase between my 2 channels. I am able to set my oscilloscoop to measure the phase so it is showing on my display of my oscilloscope.
But i tried for hours to get this value of my oscilloscope to my pc. I'm pretty sure that i need to use the vi called "Query Automatic Measurement Result" to get the result of what i placed in 'Measurement 1'. But i really don't know how to use this properly. Therefore, I assume that you first need to enable it with "Configure Automatic Measurement". But i keep ketting the same error "Undefined header" and i do not know why. Do I need some kind of trigger or acquisition or to deactivate something first, I really don't know. I hope that somebody can help me.
(3,942 Views)
Hi Biboob,
can you please share the part of the LabVIEW code that is causing the trouble? I'll try to reproduce it and suggest a solution.
Milo
(3,869 Views)
Hi Milo,
Thank you for responding. I posted my program with some explaining on the side. Text me if you need extra information.
 Greetz
Bob
(3,864 Views)
Hi Biboob,
do you want to perform auto measurements or quick measurement?
(3,845 Views)
I want to perform auto measurements.
(3,843 Views)
Quick measurements works just fine. But you cant measure the phase with quick measurements. That's why I need auto measurements.
(3,841 Views)
