RC5 Protocol
Hi
Actually, I want to decode "RC5 Protocol" directly through LabView without using any microcontroller. The type of T.V remote and TSOP1738 i am using was suitable to each other beacuse once I have made home automation system using AT89C51. In that I had written RC5 protocol using C language. But Now I'm trying to decode RC5 protcol using LabView and then trigger some action depending upon the button pressed.
I have made the Hardware setup as showing in Picture. Please point out if something is missing. Also an VI(Serial receive using VISA) but when I trying to get some data by pressing button of my philips remote. Nothing is showing up in received byte. Varied baud rate suitable to TSOP i.e<= 2400 bps.
Please help.
Regards
Gaurav Sharma
(3,657 Views)
Can you attach your VI?
Kudos and Accepted as Solution are welcome!
(3,630 Views)
Yes Sure. This only serial Read vi which is i am using.
(3,620 Views)
