RDA with SCXI-1127
I have an PXI-1010 chassis with a NI-4060 DMM in slot 8 and a SCXI-1127 in
slot 4. The SCXI is controled through the internal bus. I am wondering how
I can control the SCXI-1127 with NI-SWITCH from a remote computer through
RDA(Remote Device Access).
(2,605 Views)
Hello;
To have a RDA process running, you need first to start the RDA server at the machine that has the hardware (go to Start->Programs->National Instruments->NI-DAQ->Remote Device Access Server). Then, create the virtual channels you want to monitor remotely.
At the remote machine, go to MAX, right click at Devices and Interfaces, select create new, and select the RDA/Ethernet Device. After you configure the IP address to be the address of the remote machine, you should be able to access all the remote virtual channels.
Hope this helps.
Filipe
(2,605 Views)
