RE: ActiveX Data Objects to SQL Databse...
Hiii All,
I need literature on ActiveX Data Objects and SQL Database connectivity with reference to LabVIEW software.In my program i want to use SQL, So i need full decriptive literature by which i can easily understand  how to write program for the same on LabVIEW.
Regards
Puneet
(4,057 Views)
Most ODBC interfaces written for LabVIEW use ADO. NI sells a DB toolkit, which you can find by searching the site.
If you search online you can find a free toolkit called LabSQL and if you search the LAVA forums, you should find an ADO toolkit and a set of VIs which use an external DLL and which should be platform indepedent.
If you don't know SQL, there are many tutorials available online through a simple Google search.
___________________
Try to take over the world!
(4,044 Views)
The best source for data on ADO is Microsoft. Their online documentation is excellent. Go to the Microsoft website and do a search for MDAC. For more info on the process in general, checkout this thread.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,006 Views)
Oops... Didn't notice I had already replied... Duh...
Mike...
Message Edited by mikeporter on 01-03-2008 10:52 PM
LabVIEW Champion
(3,978 Views)
If you haven't already done so, you should take a look at LabSQL, which provides a few packaged VIs for communicating with databases. Still need to know what you're doing with database, though.
(3,962 Views)
Thanks to all,
i got the solution.
(3,943 Views)
