12-09-2007 03:03 AM
Hi
I have number which saved into xml file , i build a vi to read from xml to labview , this number is indicator , if i want to change this number with new value and saved it in the same file
, change this number to control so i can change it
can i do that
It kind of data base from xml ( read \ write )
Thanks for your help
12-09-2007 04:55 AM
You have seen the Labview examples...
If you combine them you can read and write to a xml, in one vi.
For testing you can delete most of the code and keep only the "read to xml" and "write to xml".
I am not sure what is your question..... please be more clear...
12-09-2007 06:06 AM
12-09-2007 09:46 AM
