REALLY NEED URGENT HELP with typedef struct char in LabVIEW
So I am calling a DLL inside my LabVIEW VI.
Inside the DLL, I have the following structure:
typedef struct
      char string[21];
} Geo_Tuple;
Then I used it here in a function by calling:
set_Geo_Coordinates(const File_or_Interactive State, const Input_or_Output Direction, const Geo_Tuple coordinates)
(Note that File_or_Interactive and Input_or_Output are typedef enum.)
So now, I am trying to implement this function in LV using the Call Function Node.
However, it's not working --> const Geo_Tuple coordinates does not have the correct structure.
So my question:
How do I implement
typedef struct
      char string[21];
} Geo_Tuple;
So that I can use it here: set_Geo_Coordinates(const File_or_Interactive State, const Input_or_Output Direction, const Geo_Tuple coordinates)
Thanks!
(3,252 Views)
How have you configured your call library node?  To get a representation in LabVIEW of your Geo_Tuple type you'll need to create a cluster that contains 21 U8 elements, which you can do by creating an empty U8 array and wiring it to "Array to Cluster" set to 21 elements.  Connect this to the input side of the call library node.  On the output side, convert back to an array, and from there convert it to a string.
(3,224 Views)
