RELAY CONTROL USING USB-6008
Well, that VI will simply turn the relay on/off at the duty cycle of the square wave. Your comments indicated you wanted to be able to do this "on demand". This means you need a toggle switch on the front panel to control the relay's state.
Message 11 of 20
(2,666 Views)
By inserting the boolean switch, i got an error message. The error message was like this
"you have connected a scalar(non-aray) data type to an array of the the same data type. This type conflict may be resolved by building the scalar type into an array. check for tunnel on a loop that has indexing incorrectly disabled.
the type of the source is boolean(TRUE OR FALSE)
the type of the sink is 1-D array of boolean(TRUE OR FALSE)"
So, i planned to introduce simulation. and the stop button would control the process.
sir, suggest me in removing this error please... i need the boolean control or anything which will make relay ON and OFF
Message 12 of 20
(2,653 Views)
I guess the easy way  is to drop the Switch into an array control on the front panel.
Alan
Message 13 of 20
(2,637 Views)
thanks for your idea, i think it'll work.  i'll check this method and let you know sir
Message 14 of 20
(2,631 Views)
Accepted by topic author BYm
The reason you are getting that error is that the DAQ Assistant uses dynamic data. You cannot convert a single Boolean to dynamic data. You need to feed in an array.
Actually, that's not the easy way to do it. Why would you put a single switch into a front panel array? Smiley Surprised  The easy way is to simply use a Build Array on the block diagram.
Message 15 of 20
(2,624 Views)
(FORGOT to mention I added the second I/O line to the express DAQ assist)
Message 16 of 20
(2,605 Views)
hello sir, really thanks for your great idea. Finally, It worked for meSmiley Happy.... as you said i chose the array control in that, i replaced control with a boolean one.
the other way in the front panel can also be done like this, BOOLEAN SWITCH > DDT(TO DYNAMIC DATA) > GENERATE DIGITAL SIGNALS(DAQ).
Message 17 of 20
(2,568 Views)
sir one more question, how can i make this fully automatic which will make this relay ON ( say for 10sec), then again OFF. And this cycle has to be continued ON and OFF. what i mean to say is without using the BOOLEAN switch how can i automate this cycle?
Message 18 of 20
(2,566 Views)
hello sir, thanks for your great supportSmiley Happy. Now the 1st stage problem got solved, i may use this multi relay idea what you said, in future. Great! well i think this is the easiest way to solve this program, i hope this is not POOR programming but its PURE oneSmiley Wink
Message 19 of 20
(2,556 Views)
You need to change it so that the Boolean triggers the initiation of the operation. Then you can just keep track of the time using a Tick Count or a Get Date/Time In Seconds or you can use the Elapsed Time Express VI. You can use shift registers to keep track of the current relay state. Attached is a simple VI to get you started.
Message 20 of 20
(2,542 Views)
