REPORT GENERATION TOOLKIT
I'm working and developing software on the LabView 2009 (OS Win 7) and I have encountered this problem in the block diagram:
  • in "functions palette select" Report Generation
  •  At this point there are some vi    who will not give me problems while others (like "save report to file.vi", "dispose report.vi ",...) I can not drag them to the block diagram ...
  1. the vi above there are in my library (C: \ Program Files (x86) \ National Instruments \ LabVIEW 2009 \ vi.lib \ Utility \ NIReport.llb \ Excel)
  2. I have just try to repair the packet "Report Generation Toolkit for Microsoft Office"
  3. The license is active
     What can it be? Incorrect reference library? It 's a bug in Labview 2009?
Thank you
Davide
Thank you
(2,682 Views)
Try this, You know the path of the library right.So go to "function palette>>select vi" go to that path and select the vi that is giving you the problem.
Lets see if you can use that vi in this way.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,676 Views)
