REST API SHA512
Hi
I am trying to connect to a service through a REST API which requires identification with api keys. In the instruction manual (for Python) it is stated something like
mySign = hmac.new(bSecretKey, bSign, hashlib.sha512).hexdigest()
I have no idea how to do this hashing sha512 in Labview (pyhton is not my thing, I figure I need to output a string in Hex  ?)
Thanks for any help
N
(3,465 Views)
I don't know the answer, but the way I would approach it is to start by searching for "hmac.new", which tells you this is from a Python module for implementing the HMAC algorithm, so the next thing I would do would be to search for HMAC LabVIEW or HMAC .NET or HMAC DLL to see if there existing implementations.
If I really couldn't find anything (and that's doubtful, as at the very least, the .NET framework has a built in cryptography class with many common algorithms), then you could search for the algorithm and implement it yourself.
___________________
Try to take over the world!
(3,408 Views)
One option would be https://lvs-tools.co.uk/software/encryption-compendium-labview-library/.
Yes it's a little overkill for just the SHA algoritme, but you mentioned REST API which this library also supports in a more flexible way than the LabVIEW HTTP Client VIs.
Rolf Kalbermatter  My Blog
(3,393 Views)
Hi
Thanks for your answer. I saw that package but it's a bit pricey for what I want to do. I think I will use a DLL or a python node
N
(3,385 Views)
Accepted by topic author nitad54448
There is a great LabVIEW implementation of the .Net crypto tools available here:
https://forums.ni.com/t5/Example-Code/Cryptography/ta-p/3494085?profile.language=en
(3,373 Views)
thanks !
(3,363 Views)
