REST interface
Hi All,
I would like to raise this post also. What is the status of LabVIEW REST API?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 11 of 13
(2,355 Views)
I'm not sure if you've found what you're looking for or if this helps but there's a toolkit developed by JKI SW, I played around with it and it has all the HTTP commands packed in a nice way.
I'm building an application using it, so far I only used the GET command and it works flawlessly!
Package link: http://jki.net.s3-website-us-east-1.amazonaws.com/tools#easyxml/
https://github.com/JKISoftware/JKI-REST-Client
Message 12 of 13
(2,296 Views)
JKI's HTTP REST Client is also available directly on NI's Tools Network: HTTP REST Client by JKI
Of course one could also implement a REST client manually using LabVIEW's HTTP Client VIs palette as discussed as second option here: How to Connect to the Tinymesh Cloud Service API?
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 13 of 13
(2,281 Views)
