RETURN PRODUDUCT
I HAD A MISTAKE BUYING A NI-9205, CAN I RETURN THE MODULE TO CHANGE IT BY OTHER MODULE TAHT I REQUIRED?
IS THE SAME MODEL, BUT I REQUIRED DIFFERENT CONNECTION TYPE
THANK YOU
(2,165 Views)
The forums can't help with that kind of question.  You need to contact NI directly.  Call customer service.
PS:  Where did you buy your keyboard?  You should contact them as well and see if you can return it.  It seems that it is broken with the CAPS LOCK stuck on.
(2,126 Views)
