RFID
How to interface RFID with LABVIEW? How to obtain the output of an RFID reader,which is in the form of a code(or tag name) and use that output in LABVIEW? Any specific DAQ card is suggested for interfacing RFID with LABVIEW? If possible show me an example code?
(4,308 Views)
The answer depends entirely on your reader. Did you try a search? http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/rfid/
(4,297 Views)
I am trying to use LV for Programming RFID tags. I am using Impinj Speedway r420. Has anyone tried to communicate with the Reader using LV?
(3,980 Views)
I'm using PN532 breakout board to read RFID tags and USB-8452 I2C/SPI interface to communicate it with the pc. I couldn't find a proper way to code this to read the UID of the tag. Can you help me with this? Have you got any example code?
(2,074 Views)
