RGB denoising
I have an RGB image with some noise I want to filter.
I want to do that by using Daubechie's wavelet.
the idea is to decompose the image to the R,G,B fields, wavelet transform for each, pass through a threshold and then recompose.
my problem at the moment is that when I try to perform the built-in Daubechie wavelet transform to any of the field array ( R,G,or B) I get zeros as result (the array is not empty).
any insights on how it should be done?
Message 1 of 12
(5,321 Views)
Hello, nihm,
could you send your vi?
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 2 of 12
(5,317 Views)
nothing really compilcated
first image I decompose the image (checked it, it's ok)
second - trying the wavelet transform
Message 3 of 12
(5,313 Views)
I forgot to add, that as far as I can see the error is just after the wavelet transform. nothing comes out, therefor what follws doesn't work (is there an edit option to messages?? couldn't find it)
Message 4 of 12
(5,306 Views)
did you try to connect error terminal? to see if there is one
is your X entry a 2 power lenght ?
 ps : you can edityour message few minutes ( i don't know how 2-3) after posted : option-edit...
Tinnitus
Message Edité par tinnitus le 01-28-2009 10:33 AM
Message 5 of 12
(5,299 Views)
how do I check if it's a power of 2 length??
I didn't change anything in the image (except decomposing)
Message 6 of 12
(5,288 Views)
by definition wavelet decomposes signal by 2 by 2by 2....
length tools could be find in array palette then enlarge indicator to see both dimension
Tinnitus
Message 7 of 12
(5,284 Views)
so, do I need the size of the 1-D array to be a power of 2, or just even??
Message 8 of 12
(5,282 Views)
power of 2...
did you connect erreur terminal ?
Message 9 of 12
(5,266 Views)
The error I'm getting is -23053, and the size of the array is not a power of 2.
I'm guessing I should create a ROI which is a power of 2 and then do the filtering, or something like that??
(and thank you for taking the time to help me)
Message 10 of 12
(5,250 Views)
