RGB
Hi, I have an idea of making different color paints from RGB values that is obtained by color to RGB.vi . I don't know how much i am correct in this concept technically. If it is not possible, let me know why i cannot do this?
     I  did a little code using vision aqusition VIs.
Note : In the code, shown in figure, camera captures only one color when VI is running. I have taken centre pixel to get RGB value from that image.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(4,855 Views)
Hi Hans,
what's the exact problem?
Does the code in the second frame give the expected result?
(4,830 Views)
Hi, i got correct vaues. I have checked it a lot. What i need to know is , can i apply this code in real life to using paint mixing machine get a paint by mixing Red, Blue and green paints whose values are extracted from the image taken by camera  ? is it possible?
Best Regards,
Dhans 😉
Kudos are welcome 😉
(4,820 Views)
Hi Hans,
yes, that's possible…
(4,807 Views)
Smiley Wink thank you 🙂
Best Regards,
Dhans 😉
Kudos are welcome 😉
(4,797 Views)
