RIGOL DM3058 and DM3068
I need to use a RIGOL  DM3068 meter for automatic  temperature measurments (VIA GPIB interface). I have downloaded the VI labrary from here:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7056A63387FD22BFE04400144FB7D2...
I am using the 2016 version.
Actually the DM3068 link leads you to the DM3058 instrument site (the one I provided the link for).
The trouble is that the VIs provided do not have the temperature measurment feature. The further trouble is that the DM3058 programming manual does not mention temperature at all. Perhaps DM3058 does not support temperature measurements. Unfortunately, I could not find a programming manual for DM3068, which DOES have the temperature measurement for sure (we can set it up manually in this mode).
So I guess, my question is - has anyone found the commands needed for the programming of the temperature measurments via DM3068? Or does anone have the VI with this function already? Otherwise I can measure voltage, current, resistance and so on with the available VIs provided via the link above, but not temeperature.
Note, the top VI of the donwloaded VI liabrary has a selector control for selecting the measurement mode, and somehow the temeprature is in its dropdown menu. However this selector is connected to the subVI, which, in turn, has a similar control, which does NOT have temperature as one of the possible measurement options.
Anyway, if someone knows the answer, please let me know.
Alex
Message 1 of 1
(303 Views)
