RIO not seen by project
I have a 7133 RIO FPGA PXI card.  It is seen by MAX but not available through "my computer" in a project.  The card may have been moved to a different PXI slot after initial installation.  Any suggestions?
(2,758 Views)
Hi Ken,
do you have any other cards installed in your pxi?
I'm asking because we had the same problem with an 7131. It didn't work as long as we had an 6653 Timing Module installed.
NI-Support delivered some information to the problem:
http://digital.ni.com/public.nsf/allkb/ECD4F3D186F9C60B862574890050C8D4?OpenDocument
As a quick solution we uninstalled the 6653, but we still have an open issue with this.
Thomas
(2,740 Views)
Accepted by topic author ken@ngc
The problem went away after uninstalling the PXI-7833 drivers and FPGA module and then reinstalling.  All cards in the PXI chassis (which is full) are now recognized in MAX and the 7833R appears as a target (formerly it did not appear as a target).
(2,725 Views)
