RIO resource name question
I have a request to change the RIO resource name (not the alias), I think this is automatically generated and not some thing I can set. If I'm wrong could someone show me how and if I'm correct could someone point me towards documentation?
Thanks in advance
Emma
(4,618 Views)
Accepted by topic author EmmaAgain
Hello Emma,
I'm Nick, Applications Engineer at NI.
You are right, there is no way to choose RIO resource name manually. It is the same principle as with port numbers.
I do not see any documentation, it is implicit, and also it is the very reason we introduced aliases.
Everything has an End, and you get to it only if you keep on
-E. Nesbit
(4,566 Views)
Thanks Nick,  I will feed that back.
(4,563 Views)
