RLC circuit (mathscripts) Where is the problem
I'm trying to simulate a RLC circuit with labview using mathscripts but the problem is that the output M of mathscripts nods is disable or black color
(4,031 Views)
Since you are probably supposed to be learning LabVIEW, do the (really simple) math in LabVIEW.  Think about whether you want to work with real or complex numbers -- if the latter, there is a Complex sub-palette on the Numeric palette.
Bob Schor
(4,020 Views)
Thank you for your reply sir
Yes sir I would like to work with real numbers
And I would like you to help me
And I think it is a simple circuit
(3,926 Views)
Please don't use code tags when posting regular text. Thanks.
(3,922 Views)
