RLS encoder slow down while loop execution
Why use 2 build arrays and an insert into array to build an array? (That's a rhetoric question, no need to answer.)
Build array can be extracted to build an array of 3 elements:
Message 31 of 33
(1,289 Views)
I used the Write Text File function and I got my data values in columns, Is there anyway to change it to rows instead (Without using Write Delimited Spreadsheet) ?
My current data is collected in this format
Thanks in advance!
Ryan
Message 32 of 33
(1,252 Views)
Hi Ryan,
Yes!
Use ArrayToSpreadsheetString before your WriteTextFile function to convert your array of strings into a delimited string…
Btw. you don't need the file position to "End" when you open the file in "replace or create" mode. Setting to "End" only makes sense when opening the file in "open or create" mode to be able to append new data to existing…
Message 33 of 33
(1,247 Views)
