RMS PtByPt
I am having some probles with this vi.  Can someone explain exactly what the sample length is?  I'm trying to calculate the RMS value of data for only n loops at a time.  I want it to take in n data points, calculate the RMS for this set and then start over and calculate the RMS of another set of n data points.  Do I need to set the sample length to n?
When I have set the sample length to n, it appears to work initially, but after 2n loops have occured, the indicator it is connected to shows an ever increasing number, clearly not an RMS value.
(2,591 Views)
(2,581 Views)
