RS-232 commulication
how do make a connection through RS-232 serial port with the computer?
do i need a DAQ card that can connect RS-232 or i can just connect my
device to computer's serial port and make the computer communicate
with my instrument? if i don't need DAQ card to do so, how do make
the computer talk to my instrument through RS-232?
thanx
(2,834 Views)
LabVIEW has VISA, a general purpose interface tool, and CLASSIC serial port handlers.
VISA is more efficient at runtime, but requires drivers to be installed (if you build an executable to be run outside the development system).
CLASSIC drivers use the built-in serial handlers.
No DAQ card is necessary, unless you want more ports than are built in to your system (I've programmed a system with 32 serial ports).
Use VISA CONFIGURE SERIAL PORT to specify baud rate, parity, etc.
Use BYTES AT SERIAL PORT to detemine how many bytes have been received.
Use VISA READ to fetch that number of bytes.
Use VISA WRITE to output bytes to your device.
Steve Bird
Culverson.com
LinkedIn
(2,834 Views)
