RS 232 to USB
I have to design a labview program that takes data from pressure gauge using RS 232 and USB . Does anyone have a ready made if not idea of how to do it?
Thanks a lot in advance.
(1,147 Views)
USB to Serial converters will install a "virtual" com port. Communication with an instrument through a USB to serial adaptor using the virtual com port and VISA is no different than communicating with a instrument connected to an actual com port.
Watch this video to learn the best way to do it:
VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
(1,140 Views)
What sensor are you using?  Do you have a manual explaining the communication protocol?
(1,105 Views)
