RS-485 Comm between cRIO and host?
We want to connect our cRIO to our host-PC on a distance of about 200m.
Ethernet supports max. 100m. So is there a way to use RS-485 communication,
which allows for larger distances?
Or do you have other suggestions?
Thx,
Thomas.
(3,172 Views)
Hi Thomas,
So is there a way to use RS-485 communication, which allows for larger distances?
NI sells a cRIO module with RS232 and RS485 interfaces…
Use a repeater for your LAN connection!
Or use glass fibers…
(3,167 Views)
Thanks for your suggestions.
Regarding the Rs485 cRIO module : Can this module also be used to do the host communication instead of the onboard ethernet NIC?
(3,164 Views)
Hi Thomas,
it's a RS485 interface and YOU can do any communication you like to - even with your host running YOUR VI receiving data from your cRIO…
What exactly do you understand by "host communication"?
(3,145 Views)
